I was cutting a pocket toolpath 3/4" deep with a bowl cut Jenny, once the path was complete, the spindle dropped down an additional 1/4" and started cutting the same path. The piece I was making had two of the same pocket toolpaths on the same file it cut the first pocket correctly but the 2nd ruined the piece.
Any help/insight on the problem/cause would be appreciated.
Hi there. Frankly it is not possible to debug without addition information. What CAM software are you using? Can you post your gcode or project file?
On the surface Iād say the second tool path was not configured properly, but I have no information to base that claim on.
If you have 2 pocket tool paths and the 2nd one has the issue, id be looking into that tool path for the issue
