Just placed an order for a Woodworker and have a spindle question. I’m going to do either a 110v 800w or a 220v 2.2kw spindle. If I use the break out board to control the spindle through the Onefinity controller…two questions:
Can I control the spindle speed on the fly? In other words, can I increase/decrease RPM through the controller when a gcode is in progress?
Does the Onefinity controller allow adequate time for the spindle to spin up to full RPM before initiating the cut sequence? Consider in initial startup, tool changes, pausing the run, etc
Thanks in advance!
