Turning toolpath Fusion 360
I have setup a mini lathe on my Onefinity woodworker and am trying to implement turning tool paths in Fusion 360. I know I can reassign the axes in the buildbotics controller so I thought I would generate the tool paths I need in fusion, use the post processor, and then upload to my Onefinity after reassigning the Y-axis as the Z-axis, Z to X, and X to Y.
Onefinity post processor just won’t output the file I need (see below). Is there some trick here, or would this kind of capability available only through an overhaul of the pp? I don’t know if anyone else has done this.
My intention is to mount an actual lathe cutter to the machine - I’ve successfully done this by generating a milling tool path, but there are a few specific settings I would like to take advantage of.
Information: Configuration: Onefinity
Information: Vendor: Kirbre Enterprises Inc.
Information: Posting intermediate data to ‘/Users/michaelborkovic/Library/CloudStorage/Dropbox/G-Code 2023/LATHE SETUP/4th axis neck plug - Setup5 - 1001.nc’
Error: Failed to post process. See below for details.
Start time: Tue Feb 20 00:07:37 2024
Post processor engine: 4.6050.0
Configuration path: /Users/michaelborkovic/Autodesk/Fusion 360 CAM/Posts/onefinity.cps
Include paths: /Users/michaelborkovic/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Thu Dec 7 22:50:48 2023
Output path: /Users/michaelborkovic/Library/CloudStorage/Dropbox/G-Code 2023/LATHE SETUP/4th axis neck plug - Setup5 - 1001.nc
Checksum of intermediate NC data: 3bbcdae86bc459384770c97300ca4934
Checksum of configuration: f999839a2829b06e87e2f580d3ed944c
Vendor url: https://www.onefinitycnc.com/
Legal: Copyright (C) 2012-2022 by Autodesk, Inc.
Generated by: Fusion CAM 2.0.18220
Error: Turning toolpath is not supported by the post configuration.
Failed while processing onOpen().
Error:
Error: Failed to invoke ‘onOpen’ in the post configuration.
Error: Failed to execute configuration.
Stop time: Tue Feb 20 00:07:37 2024
Post processing failed.
Hello Mike - where did you get the post process from? Is it the community version or the one provided by OF? Or something else?
It’s onefinity’s processor
What version of Fusion (Personnal or Professionnal) are you using because I’m not sure if personnal version suport 4th axis and if message restriction is clear. (réf.: Fusion version comparaison )
