Usb problems help
tried 4 different usbs sometimes works most times not displays volume control no g code files when i plug it house computer usb needs to be repaired. I had to bring control box in house to load files heard raspberry pi are fussy about usb
sticks
To format a USB that Masso will accept . . .
Open a command line running as Admin
Type the following . . .
Diskpart
List disk (find external disk number, ie disk2)
Select disk2
Clean
Convert mbr
Create primary partition
Active
Format fs=fat32 quick
Assign
Exit
Masso only takes a USB of 32Gig or less, must be fat32 and mbr.
