I’ve been trying to resize a dxf file in VCarve so I can make it on the 1F. Does anyone know how I can do that?
After the DXF vector is imported (should show up as dotted line) go to ‘transform objects’ and select ‘set size’. There you can designate the size by inch/mm or percentage.
edit: I should note that you may have to zoom out afterward to see it and move it to your job zero. Easiest way to move it for me has been to use the ‘align objects’ option. (you don’t even have to zoom out that way)
