Text size in Vcarve Pro v12
I’m pretty new using Vcarve Pro Version 12. In the text tool Vectric uses “bounding box” I think to control text size. Am I correct? I am having trouble controlling text size. Can someone lead me to a YouTube or Vectric tutorial about controlling text size in Vcarve Pro v12? Thanks
You have the text in a box, and also regular text.
If you are putting the txt in a specific location, you can adjust the size as a whole as long as the txt is still grouped. Or you can use the sizing tool to get the txt to fit the best.
Also look up Garrett (IDC Woodcraft)
Klye (Learn your cnc) both on tubeyou
When you open the Text Tool, there are two buttons at the top for you to select Text in a Box where the box will control the size of the text, or Regular Text where you determine the font size…
