VFD upgrade to 220v
Just had my garage wired for 240v-30amps breaker.
Curranty I’m running my chinese vfd & spindle @110v.
Is it possible to upgrade my vfd to 220v and still keep my 110v spindle?
Or do I need to upgrade both to 220v?
These are my vfd and spindle.
From all that I read about this, you will need a 220v spindle and VFD.
@Avbates
All I could find was: can a 110v VFD run 220v spindle, but could not find anything the other way around…
Tnx
A 220 volt spindle definitely requires a VFD with 220volt feed to the spindle. A 220volt single phase input VFD will output 220volt 3 phase to the spindle. So, a 220volt input VFD will require a 220 volt spindle, a 110volt spindle will be overloaded
@Mark_Markus @Avbates
Thank you, that what I thought I have to do.
I’ll keep this one as a backup, and will switch to 220v.
I’ve had great luck with the cheap Huanyang VFD + Spindle combos from eBay. Make sure if you buy one with liquid cooling that you specify you want a 110v cooling pump.
