Giving up. On my vfd
I own a
no proper connections and support for RS +,-
And it does not play well with others
I have my water cooled spindle working great and can run it manually. I want to be able to use the controller.I have this spindle
Please recommend the correct vfd if possible,I hate to scrap more than the vfd.
I pulled the trigger befor I knew what I was aiming at!
Thank you all
Here is the one I bought for that spindle. Go for the 2.2k incase you want to upgrade later
Amazon.com: VFD 220V 2.2KW 3hp Variable Frequency Drive CNC VFD Motor Drive Inverter Converter for Spindle Motor Speed Control HUANYANG HY-Series(2.2KW, 220V): Home Improvement
Scott,
I was wondering if it was ok to buy a vfd for a 3hp motor and run a 2hp for awhile until I’m ready for a motor upgrade and a 80 mm mount .Scott are you able to control your motor using the1F controller?
sure can here is a great you tube
(1669) How To Install A CNC Spindle - Part 1 - YouTube
No problem running a larger VFD than your spindle. Just set the max amps to match your spindle, and you’ll be fine. It’s one of the 100+ settings available to you…
Scott ,
I just ordered the vfd, wish me luck, at least I will now have a common vfd.
