Hey Guys,
I’ve noticed some weird circles in my carved projects when using multiple text styles. I can’t figure out why they are appearing or why the machine is creating them. Has anyone else ran into something similar? The bit is an Amana 90 V-Bit (RC-45711).
Cheers,
Trevor
I would think those are in your file, they look a lot like the adjustment points common in the text file. I don’t know what your using but if its illustrator I’d convert to shape and export again. Unsure if/or how that might be the case in what your using.
I’m using V-Carve pro and literally creating text and carving it with the 90 V bit mentioned above.
Yes sir, only the 90 V-bit.
What kind of toolpath(s) are you using?
What does the toolpath look like in the software — screenshot?
Can you export the text as an SVG for reference?
I just sent you two of the files to your inbox.
