What Spindle/VFD/ATC should I buy for my Onefinity?
Onefinity CNC only officially supports the use of Onefinity CNC Spindle kit by Redline CNC.
Shop now:
Blog Post
Technical Support and Warranty
One important point to consider is that Onefinity does not offer any technical support for any spindles other than the Onefinity Spindle Kit by Redline CNC or Makita Trim Router.
When using any other spindle than the above, Onefinity will not be able to provide technical support and may ask you to remove your spindle to diagnose any machine issues you may have.
Onefinity is not responsible for any damage or injury from improper wiring of aftermarket, unsupported VFDs, spindles or ATCs. If it is not sold directly from Onefinity, it is considered aftermarket. Use of these aftermarket products may void your warranty. Please use at your own risk.
Z Drop:
Also note: use of 80mm spindles / ATCβs may cause your spindle to drop when power is cut or estop is pushed. The elite series has a brake to prevent this here:
