Day 4 of 2024 release Week! Introducing the Onefinity Spindle Kit by Redline CNC
Introducing the Onefinity Spindle Kit by Redline CNC.
The Onefinity Spindle Kit by REDLINE CNC
Onefinity Redline spindles are the most advanced plug and play spindle kits on the market today. Featuring a sleek and stylish patent pending design, compact all metal enclosure, A high quality custom made spindle with four ceramic bearings standard. In addition, it’s the only safety approved plug and play spindle kit on the market today. No other spindle kit on the market has the quality, reliability and safety that the Onefinity Redline spindle has!
Onefinity Spindle Kit by Redline CNC | 80mm 2.2kw Air Cooled 220v
Buy Now
Onefinity Spindle Kit by Redline CNC | 80mm 1.5kw Air Cooled 110v
Buy Now
Onefinity Spindle Kit by Redline CNC | 65mm 1.5kw Air Cooled 110v
Buy Now
100% Supported
100% Plug and Play
100% Metal
100% Covered Under Warranty
100% Awesome
Join our LIVE YouTube follow up to get an up close look at the new Onefinity Spindle Kit by Redline CNC https://youtube.com/live/Wy9lmPEVFpM
What you get:
  • Ready to go, safety approved , complete Spindle Kit
  • Compact custom designed all metal VFD enclosure
  • Custom made, high quality spindle with quadruple bearing supported shaft
  • Ceramic bearings standard on all spindles
  • All wires and cables properly grounded and shielded
  • Detachable display with built-in manual over-ride switch
  • All power lines and electronics properly filtered and grounded
  • Sleek and stylish patent pending design
  • Quick and easy set-up. Plug and play
  • Three (3) great mounting options
  • Works with all Onefinity machines
And much more…
Cool, Stylish, Compact All Metal Design
Redline encloses the VFD electronics inside a sleek and stylish all-metal VFD enclosure. Not only does the enclosure look amazing, it also dramatically reduces EMI and heat issues. Many of the competitors use plastic housings leaving you susceptible to glitches and disconnects as well as premature failures due to EMI and heat.
High Quality Spindle, FOUR (4) Ceramic Bearings
Onefinity Redline spindles are custom made, high quality spindles with a quadruple bearing supported shaft and come standard with 4 (Four) ceramic bearings . Ceramic bearings reduce rolling resistance, increase durability, increase stiffness and minimize damage caused by cold starts. Ceramic bearings can last up to 20 times longer then Steel bearings, offer reduced friction and use less energy. Furthermore, ceramic bearings can operate in harsh environments due to their resistance to corrosion and degradation.
Wires and Cables Properly Grounded & Filtered
All internal cables and wires are properly shielded, grounded, filtered and isolated where required. Our Spindle cable is also shielded and properly grounded and features a High Frequency noise filter that keeps the VFD noise were it belongs, inside the enclosure. All our Input control signals use shielded cables that are properly grounded and input filters for noise free control. You will not find a higher quality Spindle Kit anywhere!
Detachable Display With Built-In Manual Override
Onefinity Redline CNC spindle kits feature a detachable display with a built-in manual override switch that can be mounted in a convenient location, whether it’s on the wall, VFD, or other convenient locations. The manual mode switch allows you to adjust the speed if your controller can’t.
Industry First Safety Approved Spindle Kit
Why did we choose Redline CNC to be our official spindle? It’s simple. Safety.
Redline CNC and Onefinity is very excited to introduce the industry’s first and only safety approved plug-and-play spindle kits. Having a safety approval ensures that no shortcuts were taken and guarantees the Spindle Kits are of the highest quality, reliability, and safety for our customers.
Onefinity Redline CNC Spindle Kits were design with convenience in mind, that’s why we offer three (3) different VFD mounting options.
VFD Mounting options include:
The Onefinity REDLINE Spindle is available in 3 models
  • 65mm 1.5kw Air Cooled 110v
  • 80mm 1.5kw Air Cooled 110v
  • 80mm 2.2kw Air Cooled 220v
Get your Onefinity CNC Spindle Kit by Redline CNC today!
Buy Now
Buy Now
Buy Now
Is the 1.5kw 80mm ER20? Also what is the current rating on the 80mm 220V unit?
Yes both 1.5 and 2.2kw 80mm are ER20
Does this mean we will get ATC?
Is there any info on how loud it is? Or maybe video of it showing a sound comparison with the makita router?
O FOR sure you will like the noise level way better vs a “Makita router” I do not know why anyone would put a “Makita router” on a 1F
Troll much? Because that is what Onefinity has recommended literally forever, and spindles were not officially supported up until now.
Not sure what you are talking about, Whats to support?
We will have stock in our warehouse to ship out directly with any orders from our site!
What will the baseline firmware requirement on the BB controller be for the plug and play of the 4th axis and the RL Spindle? I have been holding off upgrading because I am comfortable with the version I am on.
What are the power cord types for the 220v version?
really wish you had released this before i purchased another brand 4 months ago…
Oh well, atleast you have one now.
Same here. I will say though, 2 thumbs up for metal enclosure and ceramic bearings on the redline. I’d hold out for a water cooled version though.
Does anyone have experience with Redline?
@OnefinityCNC Any plans for water cooled?
Yea thats true, Yes i bought the water cooled and the chiller. would have rather got this one with the ceramic bearings, it will draw less amps from what i see, and the support from onefinity. looks like a smaller footprint as well with the box.
No Plans for water cooled. We belive air cooled is more than enough for the majority of our customers and keeps the complexity down with less hoses and plugs and such.
Do you know if the brake motor will be needed for the existing Elite machines?
If you have an Elite machine before November 2024, you will want to order the Brake motor if you use a spindle.
There is not a brake motor option for Original or Pro series machines.
Okay, probably a dumb question, but besides the size of 65mm vs 80 mm… what’s the difference between the two? Both are 110… bigger bits? Thank you for any information! Keep up the great work you guys!
Misury
The 65 has a smaller collet, probably an ER11 smaller bits. The 80 has an ER20 collet, handles 1/4 inch bits.
