I have the file “setup”, but it only has 4 pockets no location for the tool setter, so once I installed the rapid change I simply used my trusty handheld Masso controller and centered that pin they give you right above the tool setter and use a set of calipers to get it as close as possible to the center. I figure it can’t be that XY critical, unlike the tool changer that is that critical, and that should do it. I am sure someone will let me know if I am wrong LOL
Later in the setup it should have you put the disc on the dowel to find the center of the 1st tool pocket.
i did that already yes
