Where to plug Rotary probe into BB control unit
It’s probably documented somewhere but I couldn’t find where to plug in the rotary XYZ probe into the back of the BB control unit.
Do I switch it out with my normal probe or is there a dedicated port in the BB control unit.
Thanks
Kirk
Looks like I have to switch out the probe plug back and forth between normal probing and revolution proving. Successfully probed xyz on the rotary.
Not a great solution. Worry about constantly messing around behind the control unit plugs. Hopefully a better solution emerges so I don’t have keep touching wires behind my unit every time I want to switch back and forth between the rotary and standard flat milling.
Kirk
No, you’re removing the probe wire from the wrong end. Removing it from the probe block as shown in the manual. Do not remove the wire from the back of the controller. That stays plugged in all the time.
Ah, thanks. Didn’t see it in the manual anywhere. Checked a couple of times and couldn’t find it. So, basically put the banana plug into the probe plate. Genius. Didn’t think they were compatible. Thanks for the quick response. I’ll try that.
