X-Axis adding 1000mm only during cutting
Well I have been using my woodworker pro cnc for months now with no problems. Cutting almost everyday and everything was a breeze. Well I attempted to cut a 32 inch long piece and 3/4 the way of the cut the motor has like a change over noise and adds 1000mm to the home/cutting distance. Then will continue with the cut and bounce off the limiter unit I stop it. This gives me no errors and I can not find any related posts about this issue. HERE IS THE LINK TO THE PROBLEM: https://youtube.com/shorts/g5ORB-ydGqM?feature=share
Yes I have rewritten the file 3 times to eliminate the possibility it could be in the file/coding. It is not an issue there but I know it is an issue with the machine, I tried to mess with the settings but nothing changed the outcome. I reset all to factory settings and issue is still there. Please if you have any tips or anything I need to get some orders out on Monday!
Also I forgot to add that this does not happen during jogging or any small cuts.
