X35 Woodworker tool change help request
Hey Sean,
this is done by tweaking the values of the g-code commands in the ‘tool-change’ field of the General Configuration Tab, as described here.
The Onefinity Controller does not support this. You just can pause, but after stop you can only start the g-code program from the beginning. What you can do is edit your g-code program manually with a text editor or a g-code editor to delete parts that were already achieved, but you have to take care that certain g-code commands that set modes or units are prepended at the beginning.
Welcome to the forum!
Further Reading
