Z Axis show "NO FIT" when homing
Started up the machine today, When I homed the machine the Z axis showed “NO FIT”, it didn’t effect anything. I was able to set the Z height. After it started cutting I noticed that it went back to “OVER” . The only thing that I changed was updated Vcarve Pro. Any thoughts?
Thanks
Daryl
Ignore toolpath status until you zero xy and z.
Thanks, I zeroed the X Y Z and it still stayed there. It did it first thing this morning and then about 2 minutes into the cut it went away on it’s own. An hour later I had another project to do and everything was working normal again. I will try this afternoon and see if it there again. I doesn’t effect any of the cuts, I was just curious if anyone else has seen that message?
Daryl
I am having “almost” the same issue and then when over over the “No Fit” issue the following statement shows:
“Tool path info X axis
Warning: The current tool path dimensions (816.656 mm) exceed axis dimensions (816 mm) by 0.656 mm.” I am able to do small projects-no problem as long as I home it on a different spot other than lower left, I started getting this message when trying to cut my spoilboard 32.125 x 32.125"
Any Help will be appreciated, Thank you in advance.
Try reducing your file size to cut 32” rather than 32.125. If you are using a surfacing bit, it still should flatten the whole surface.
Thank you Jonathan I will try that, will keep you posted.
Mine keeps showing up now and again but only on the Z axis, it doesn’t cause any issues with cutting and will usually go away once I start cutting. odd. I never changed any of the setting to get it to disappear. I machined for about 5 hours yesterday and it didn’t show up once.
yeah just started happening and i have no idea why uhg but mines happening when I load a file where I saved the tool paths to one file. i machine was already homed and ready to go.
i think ive stumped them. they say what im doing isnt possible lol support wont even answer me in my emails lol
First, let me state that our official support hours are Monday-Friday, 9-3 Central.
Obviously, since you were receiving support last night, on a Sunday, we try to help out after hours as well, but any support out of our official hours is a bonus. Why didn’t you get more responses back? We were all asleep :yum:
So, one of our support techs was helping you at 12:28 am, midnight, well outside of business hours.
The tech was correct, different tools must be separated into separate toolpaths. There is not an answer other than this, as it’s the only correct answer.
Some background as to why you need to separate them and you’re seeing no fit. For each ‘tool’ the controller calculates height.
Here’s an example:
Lets say the total height the z can move is 4".
Tool 1 uses 1" of height.
Tool 2 uses 2" of height
Tool 3 uses 1.5" of height.
Total heigh of all tools is 4.5"
4 - 4.5 = -.5
The controller thinks the toolpath will not fit as it would be .5 too large to run.
Why do some of your multitool files work? Because they stay within that certain heigh the Z calculates. Some wont as they will calculate too large. You don’t know until you load them, which is why, again, the answer is to save each tool as a separate file.
For this reason, each tool must be their own toolpaths.
There has been much talk about this on the forum, which is why you were directed to it, as there’s a ton of info there that one email from us wouldn’t cover (and other great information for a new user, 99% of answers to questions you may have are already answered and discussed at length on the forum). We’re not ‘passing the buck’, were just not reinventing the wheel.
Here’s some posts that talk about multitools, no fit, and the answer of saving as separate toolpaths.
https://forum.onefinitycnc.com/search?q=save%20toolpath%20as%20separate%20files
:smiley: Well, if that just doesn’t prove that no good deed goes unpunished. Just opens you up to unreasonable expectations from customers. :wink:
Very nice explanation about the multi-Z height toolpath impact.
i still dont get it still unable to run machine
I was having the “no fit” on the z axis error and was baffled by it for a few hours. I am using an older version of aspire(8.5) and found that by adjusting the home start height section that it “fixed the issue for me”
How did this work? You added almost an inch to the z start height and didn’t have issues? How thick is your material? I’m curious if this is something related to your start z being incorrect (top of material vs. Top of spoilboard).
So, out of curiosity, how does one get a 10 year old version of Aspire to work? Assuming it’s cracked software, since you’d likely be an expert by now had you bought it in 2015…
I am not an expert. I work at a machine shop that runs this machine and software. They also have AXYZ router table, hass VMC and lathe machines. They started around 2014 so they are experts not me. I am relatively new to industry. I thought I would help contribute to this thread because I had an issue with the machine and it took me sometime to figure it out. I thought I would help others. I believe this error came up because the Z start position some how for me was originally place at 6.35 inches( I am not sure how but it was) by lowering it (to 0.95in) this resolved the issue for me. Again I am not an expert.
