Krisk
December 17, 2023, 10:25pm
1
Hi. Iv been struggling with my current project. And the support from this forum has been amazing!!! Im looking to get some 1 on 1 help.
Ill send over my and trouble shoot it together.
Again the people here have been so helpful. But its still not lining up for me.
Thanks
AndyP
(Badger)
December 17, 2023, 11:48pm
2
It may help people if you describe it.:
where the problems lie (modelling, toolpaths, machine)
what are you trying to achieve (3d, 2d cuts, svg signs etc)
what CAD, CAM software you’re using (carvco, VCarve, F360…)
which 1F machine you have ( elite with masso controller or pre-elite with buildbotics controller…)
Good luck.
Krisk
December 18, 2023, 12:42am
3
Good point!!
Im using a 36" one finity and carveco.
Im struggling to get my z heights figured out. Im also using it to cut marble instead of wood. So the touch probe doesnt work with my bits.
kriaz101
(Kamran Riaz)
December 18, 2023, 5:06am
4
You don’t really need the touch probe to set the origin or the z-height. But,
You can use a standard 1/4 inch bit to probe to set the origin; and
You can use the paper method to set the Z with your marble cutting bits.
Krisk
December 18, 2023, 5:26am
5
Yea i did that. But for some reason my machine is still cutting air above my material… and iv been playing around with all the variables
SailorMike
(Michael Bruck)
December 18, 2023, 6:53pm
6
I don’t know too much about CarveCo, but if it’s similar to VCarve, you should check that your Z Zero isn’t set to the machine bed while you reference your Z axis to the material surface when setting up the carve. That will produce the the symptom you are describing.
Krisk
December 18, 2023, 7:21pm
7
I did try that. But now I’m starting to think that I tried it but did it wrong lol.
Might just have to restart and log all my attempts to figure it out.
AndyP
(Badger)
December 18, 2023, 8:06pm
8
You need a Carvco savvy person. Unfortunately thats not me.
Krisk
December 18, 2023, 8:17pm
9
Thanks for your time though. It’s an amazing forum.!!
Ill get it eventually lol
