1F Transfer Files via WiFi instead of USB
How do I 1F Transfer Files via WiFi instead of USB Flash Drive?
Thank you
  1. Connect to your 1F using ip adress or http://onefinity.local
  2. Click the upload button and navigate to the folder where you saved gcode.
Oh, I see… so you don’t really need to even FTP into the darn thing! I managed to FTP into the controller, and I was scratching my head which directory do I drop the code files into. So easy peasy.
Thanks so much. :slight_smile:
If you absolutely want to upload from your cam software, instead of doing FTP to the folder /var/lib/bbctrl/upload , you can install samba and your pc will access the share. See
Gotcha, thanks again. I can’t wait to cut my first project. :slight_smile:
