Out of the box network share support for uploading gcode directly from prefered design software.
Temporary solution
note: This generage a share called ‘GCODE’ instead of ‘upload’ in order to not interfere with future 1F implementation.
# SSH to your cnc using user and password. # usually user=bbmc password=onefinity
sudo -i # enter same password
# MOUNT OS RW
sudo mount -o remount,rw /boot # makes the file system writable
sudo apt-mark hold hostapd # prevent update to hostapd
# SETUP SAMBA. REF.: https://pimylifeup.com/raspberry-pi-samba/
sudo apt-get update -y # update
sudo apt-get install samba samba-common-bin -y # install the packages that we require to setup Samba
sudo nano /etc/samba/smb.conf # save it by pressing CTRL + X then Y followed by ENTER.
# +++ replace the file content by this (remove '# ' at the beginning on each line
# [global]
# netbios name = ONEFINITY
# server string = One Machine Infinite Possibilities
# workgroup = WORKGROUP
# hosts allow =
# socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=65536
# remote announce =
# remote browse sync =
# [GCODE]
# path = /var/lib/bbctrl/upload
# comment = Onefinity_GCODE
# browsable = yes
# read only = no
# valid users =
# writable = yes
# guest ok = yes
# public = yes
# create mask = 0777
# directory mask = 0777
# force user = bbmc
# force create mode = 0777
# force directory mode = 0777
# hosts allow =
sudo smbpasswd -a bbmc # define user bbmc (when asked for psw input onefinity
sudo systemctl restart smbd # restart the samba service
cd /var/lib/bbctrl # before you can upload files, you will need to
sudo chmod a+w upload # set appropriate permissions on the RPI
# to connect from the network. use user bbmc and pwd onefinity
# MOUNT OS RO
sudo mount -o remount,ro /boot # makes the file system read-only
# RESTART SYSTEM
sudo reboot
How would you go about reversing this process so that you can access a share on a Windows machine from the controller so that it is listed under the “Other Location” tab when you click on the
Browse button?
I found this link : Raspberry Pi Documentation but haven’t tried it yet as I didn’t want to break anything on the controller.
Sound possible and you should be able to access your remote share from the 1F UI. Look at the active solution here to make your test:
note: refer to my temporary solution and use the ‘mount os rw’ and ‘mount os ro’ section. it was caveat when I started the test for my temporary solution.
This is what I get when try to run the following command :
sudo mount.cifs //192.168.0.12/CNC_Stuff /home/pi/CNC_Stuff -o user=bbmc (also tried the account name for my Windows machine)
mount error(112): Host is down
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
For those of us who use Macs and want to connect the following is my /etc/samba/smbd.conf settings.
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
# - When such options are commented with ";", the proposed setting
# differs from the default Samba behaviour
# - When commented with "#", the proposed setting is the default
# behaviour of Samba but the option is considered important
# enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
hosts allow =
vfs objects = catia fruit streams_xattr
fruit:aapl = yes
fruit:metadata = stream
fruit:model = MacSamba
fruit:posix_rename = yes
fruit:veto_appledouble = no
fruit:nfs_aces = no
fruit:wipe_intentionally_left_blank_rfork = yes
fruit:delete_empty_adfiles = yes
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
# wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
; interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself. However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
# syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
server role = standalone server
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
passdb backend = tdbsam
obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = primary
# classic domain controller', 'server role = backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
; logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
# logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
; logon drive = H:
# logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
; logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe. The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 (default) means that usershare is disabled.
; usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
usershare allow guests = yes
#======================= Share Definitions =======================
[GCODE]
browsable = yes
read only = no
valid users =
writable = yes
guest ok = yes
public = yes
create mask = 0777
force user = bbmc
hosts allow =
valid users = bbmc
# [homes]
# comment = Home Directories
# browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
# read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
# create mask = 0744
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
# directory mask = 0755
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# The following parameter makes sure that only "username" can connect
# to \\server\username
# This might need tweaking when using external authentication schemes
# valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
; directory mask = 0700
# [printers]
# comment = All Printers
# browseable = no
# path = /var/spool/samba
# printable = yes
# guest ok = no
# read only = yes
# create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
# [print$]
# comment = Printer Drivers
# path = /var/lib/samba/printers
# browseable = yes
# read only = yes
# guest ok = no
# # Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
; write list = root, @lpadmin
Hi all,
I realize this is an old post but I recently moved my files from my PC to a Synology NAS device.
When I tried to remount my share in the fstab file, something happened and I lost access to the controller completely.
After a flash of the SD card to the latest firmware, I am not able to remap to the share on my NAS device.
The share I created appears on the Onefinity controller but when I try to access it, I get a message that only the root account can mount a device and then I lose my access to the touch interface on the Onefinity.
Not sure if the two problems are related or not.
I am using firmware 1.6.4.
Has anyone been able to do this with this configuration?
If so, can you provide some step by step instructions?
If all else fails, I will try to go back to the firmware I had before (1.0.8) and see if I can get that to work.
Thanks for any help.
Thanks Scott.
I reverted back to firmware 1.0.8 and was able to mount the share on the NAS.
Next step will be to update the firmware to 1.6.4.
Hopefully, it will not destroy all the mappings and codes I have already setup for my program start and tool change.
We shall see.
