3D Printed Onefinity Enclosure
Hey all, hopefully I’m in the right area to show off some pics of a 3D printed/acrylic enclosure. My Dad purchased the Onefinity CNC about 2 years ago and hasn’t got off it since. He has it out in his workshop and while noise isn’t really an issue out there he has quite a bit of dust buildup around the shop.
We decided to put together this enclosure over the last few weeks which consists of two 180 degree hinged front doors and a 180 degree hinged hood for maximum work volume when opened up.
This picture shows the working area when the front doors and hood are in the fully open position.
Front-View fully closed
Here’s an isometric view where you can see the two front doors in the closed position and some of the supporting pieces.
Here’s a sideview with some accessories such as a 2" vacuum hose grommet, extrusion plugs and various mounts for cables and a webcam. I’ll eventually install a Pi on Dad’s wifi network and host a feed of the webcam to view a live feed of CNC progress.
Since we went with rather thin sheets of plexiglass, some additional ledge supports for the upper roof were needed, including a 2’ aluminum extrusion which is mounted between the hinged hood and static part of the roof. In hindsight if we were to do this project again, 1/4" plexiglass or even thicker may have been a better choice.
Here’s a closeup of an installed upper support with some car door trim we used for aesthetic. Nearly all of the parts are printed with a #4 or #6 hex cut for easy installation.
Here’s a closeup of a corner brace which is basically mirrored all around the enclosure, less the bottom back which has quit a bit more thickness and height to really sure up the box.
The two front doors rest on a set of polycarbonate wheels which mount to these corner brackets and are offset to the designed-in gap of "200 around all edges. The wood underneath was then slotted so they roll smoothly into place when closed. When opened the hinges are strong enough to hold the weight of the door assembly without any flex.
Along the center aluminum support there is an LED light strip mounted.
Lastly, the iPad mounting arm was too short and collided with the enclosure panel. So we reverse engineered a new one up at 8" in length and printed it up in ABS filament, and finally locked it in with some lock nuts.
Since the router sits in a metal shop all day, the majority of these parts were printed at 240c on an Ender 3 using Overture PETG. Some non-functional parts we used Esun PLA+. All in all we spent around $150 on the glass, $60 on filament (lots of testing) and some change on hardware. All of the parts were designed by myself in Fusion 360, the gear hinge was pulled from thingaverse but modified to death to work with our thin plexiglass. Everything was sliced in both Prusa and Cura slicers at either .16 layer height or .2. This was my first real functional print project and every hole, length, width, fillet came within +/-.003" of nominal.
There was definitely some lessons learned and still might be, but it was all worth it when the plastic film was torn off at the end. If anyone would like the CAD files for this project, just drop me a message and I can send you a google drive link. Otherwise, we’re open to any questions or comments.
Thanks for checking out this project.
Very impressive and well done! I think the black and glass goes great with the machine.
Nicely done! Love seeing new solutions for enclosures.
I’m looking at the photos :face_with_monocle: but I don’t see the motion detectors and criss crossed laser beams. :smile: That enclosure looks like a museum display case. A Onefinity makes a worthy exhibit. Have you found the plexi attracts lots of dust? And does it generate any static build up? And where did you find 1/8" plexi for that price? I’ve seen it here for $60.00 for a 2x4 panel !
Hey Charles, standby for v2 pics when we add those features :wink:. I don’t think anything’s been cut yet with the new plexi enclosure but I have no doubt there will be some build up. I’d imagine every few weeks it will need to be hit with a vacuum and compressed air. We sourced the glass at a local Taps Plastic, they should definitely be able to beat that price if you’ve got one nearby you can walk in to.
I haven’t noticed any significant static, but now that you bring it up it may be worth hitting the glass with a coat of anti-static cleaner for dust/static before a part is ran.
We’ll have to wait and see but I don’t believe it will reduce the noise any, definitely not as much as a typical wood enclosure seen around.
Unfortunately most of the printed parts cannot be scaled up or down. They all have specific gaps/clearances, especially the hinges which were printed in place in one go.
@Off-kilter - I found this place has great prices: Clear Plexiglass Acrylic Sheets 1/8" Thick
Discounts for 3 or more; shipping was fairly expensive though.
@cyberreefguru thanks but too late for me. Already got suckered with high price and don’t need anymore.:face_exhaling:
Hey Sean. I like your enclosure design, its super clean and I love the fact that all the joints 3D printed. I couldn’t figure out how to DM you so I am asking here, can I get the CAD drawings for this? I use Fusion 360 as an FYI if that matters.
How has the enclosure held up by the way? Do you have to clean it often? Did you end up putting some anti static coating on it?
Wow! I really nice enclosure. I’ll bet you spent a ton of time designing the pieces that put it together. A question for you is does the plexiglass create static that the tracks dust from the CNC?
I would love to build this if you still have the files available.
I am not a fan of enclosures, but this one is super sexy. Best I have ever seen. But no, I like access to my machine without hindrances. But well done I have to say.
