I’ve been thinking about doing a spindle mounted light for my 80mm spindle which isn’t really a product I could find easily so I modeled up my own 3D print and used one of those halo lights from Amazon. Good news is these fit with the Z-20 slider just fine. It uses an M3 threaded heat insert and an 8mm long M3 bolt. I was able to wire it up to the Masso using an output set to “light on/off” so you can turn it on via the MIDI etc.
An 80mm spindle light isn’t easy to find off-the-shelf, so modeling your own mount and pairing it with a 100mm halo ring is a smart move. The fact that it fits the Z-20 slider without any clearance issues makes it even better.
Thanks for listing out the parts too. Those Qasim halo rings are surprisingly bright once the cover is removed, and wiring it into the Masso with the “light on/off” output is a slick touch. Being able to toggle it through MDI/G-code is super convenient.
Nice work overall — simple, functional, and something a lot of 80mm spindle users will appreciate. If you’re sharing the file, I’m sure plenty of people will want to try this setup!
Thank you for the kind words! I meant to also post a picture and show that when paired with the Suck it SM it channels the light through the entire dust boot and eliminates that slightly darker spot you see just below the bit. I’ll post the picture later today.
See the photo with the Suckit SM on. It channels the light really nicely to the bit location.
Also worth noting if you dont have a 3d printer I might be persuaded to make and send some just cover shipping and costs for the insert/screw if you want.
@Calvin this is really great find. Stupid question though, Im not a sparky, how did you do the wiring? did you use a relay or something with the tts output ports
Personally I did use a relay because I had one but the amp draw is tiny and it works directly. What you would want to do is wire the Black wire from the light to ground and then the red wire to one of the open “output” ports on the Masso. Then go into the F1 screen and set that output to “Light on/off”. If you want it to work just like mine. There are other ways too. You could get a 12V outlet plug from amazon with terminals like I linked below and then just plug it in when you want it on etc. Same principle applies wire the black to the ground terminal on the power supply and red to the positive.
Hello,
I would confirm you have the clear plastic cover removed as it doesn’t work with that. Otherwise I would suggest measuring your halo lights. I did have one other person run into an issue with sizing and he was not sent the 100mm version as there are multiple sizes
The Halo light is way bigger than the 3D printed part. The od of the printed part is 89mm and the light is 90mm ID. Do you have to expand the printed ring so the halo light can fit to it.
So on the 100mm I ordered the clear plastic diffuser has an OD of 102.6mm and the LED PCB inside of that has an OD of 89.2mm. Maybe they didnt send me a 100mm light but with the OD being 102mm I would assume I got the correct part. Along with other folks also having the part work. I would guess they must have changed their manufacturing?
Ok thanks, I will just modify it to fit the 100mm Halo light I guess. I ordered the light you had in the link. When you click the link it has the 100mm already selected. Its no biggy, I was just being lazy and didnt want to have to modify the stl. I am not a pro with inventor so it will take me a bit. Thanks again for your help
