After upgrading my cnc to masso (wire was loose)
When starting up machine from upgrade x motor hard limit code and machine is homing in front right corner how to fix this?
Without homing, does the X axis jog in the correct directions - pos=right/neg=left?
If yes you can go to F1>Homing>and ivert the direction for X axis.
When homing it goes to front right corner instead of left and I can’t toggle to the left
Just upgraded to masso and can’t get past this point
Disable request home on start up - uncheck box (see F1>Homing) - then restart.
Next jog X axis as I described above and see what it does.
The x+ goes right fine but when I hit the x- nothing happens
Y and z goes in both directions
This what happens when I home it
Double check your connections. Sometimes if you only get a B alarm it could be a disconnected cable
It looks like from the controller picture that you have it in Step mode at the lowest increment and feed slider all the way down to 1%. This may not be related, but for the testing please move the feed to 100% and switch to Continuous jogging.
Also, when you jog X-, does the DRO change value, but the axis does not physically move to the left?
I took x rail wire out of pipe and the black wire was broken now everything is working correctly
Just finished my test carve :+1:
Thanks for all your help
