Alternative router outlet uses
For those users that have a spindle, can the router outlet on the power supply box be used for other purposes? Are there M codes to control it? The vacuum side is controlled with m08 and m09. I haven’t found anything in the manual
M3 turns it on, m5 turns it off
That’s the same code as the spindle uses. Are you saying that it would be on the same time as the spindle?
That is correct. 20 characters
Can other codes be assigned to it to make it more versatile?
No. It is wired to the spindle output.
