Assembly - X rail doesnt fit on y rails
Just received my onefinity. Great packing. Had to remove some twist in both y rails.
Im now having trouble getting the x rail to fit flush on the two y rails.
Any ideas or suggestions?
Contact Onefinity.
Phone 1-800-717-4242
Email support@onefinitycnc.com
That phone number takes you to a line that has all kinds of offers to sell things to people 50 and over. the Onefinity number is 888-717-4242
There might be a small amount of twist in the X rail, which could be straightened out just like the Y rails. If it’s not much, just bolting both sides together will straighten it out.
Thanks Bill. I tried loosening set screws on the x rail. The twist doesnt come out like it did with the y rails where I just loosened set screws and let gravity work. I have about 1/8 to 3/16 in gap on one side of x rail. Guess I will see if bolting both sides together straightens it out.
Lynn,
The x rail straightens out differently because of the third rail on it. You’d need to remove the third rail (stiffy) first, then straighten it out like the other two y rails you’ve done.
I tried to remove the 3rd rail on mine. My x rail doesn’t sit flush either. Anyone got a picture of how it should sit?
