So I have my ATC set up and everything seems to be working fine with MDI controls. The tools change properly and auto zero as intended. My issue is more when running code and I dont know if it a controller issue or a Fusion issue, so I’m hoping somebody has experience with this. After a series is complete and its time to change tools, the spindle stops and then just pauses and wont change tools and continue until I hit CYCLE START. After that it changes tools and goes about the sequence of the next tool path. So I’m almost full Auto. Help!? ![]()
Masso has an optional stop (M01) that can be turned on and off using CTRL + 0.
I have read in the forum that turning it off has eliminated the need for cycle start on some ATC solutions.
any idea how to change that from the touch screen?
You can’t use keyboard shortcuts unfortunately from the touch screen. Do you have a USB keyboard you can plug in just to toggle and test it?
