Not pausing for manual tool change using fusion 360 for masso (solved with correct post p)
I just installed the OneFinity tool setter, which mostly went according to plan/vidoes.
However, when run a job with multiple tools it will pause before a new tool is required, but it doesn’t move to the tool change position I set in the F1 screen (Tool Changer => Manual Tool Change => enable x, y, z and set coordinates). It simply pauses for a bit (rotation stops), then spins back up and proceeds with the job even though I haven’t been able to change the tool.
Also, the screen never prompts me to change tools. They do have different indices in Fusion.
What am I missing? Generating .nc files with Fusion 360, all worked as expected until I installed the Tool Setter. NC file I’m testing with is attached.
InsertTest.nc (60.4 KB)
Looking at the gcode, the M5 - which appears first - and T# are on separate lines.
Masso is looking for Tool Number first then M5 and on the same line…
For example: T1 M6
Which post processor from Autodesk are you using?
https://docs.masso.com.au/cam-post-processors/fusion-360
Not sure if this helps but, if you don’t have your tool numbers in Masso that match you CAD software there will be issues. In Vcarve, I experienced similar issues.
Thanks @Mick427 , that was an update I had to make but even after matching numbers I was still not getting proper prompts for tool changes.
I see you are quite busy answering tool change questions here @TMToronto !
I had been using the Onefinity 2021 pp. Changing to the Masso .cps you linked to does finally give me prompted tool changes! It’s a bit clunky as there are extra , unprompted steps:
  • Operation runs
  • Spindle stops and tool withdraws, but no prompts
  • Hit Cycle Start
  • Tool moves to load location and screen prompts for change
  • Hit Cycle Start after changing tool
  • Tool properly registers at Setter then proceeds
So I wish I could skip that first Cycle Start hit, but at least I can run multiple operations from one NC file and utilize the Tool Setter.
Progress!
this fusion post processor is for Buildbotics controllers and not for the Masso controller.
There may be an Optional Stop (M1) causing this.
Torn off Optional Stop - press it at top of screen to toggle On/Off
That setup was working fine until I installed the Tool Setter. Thanks for the info.
Spot on @TMToronto, that was the issue. You ever make it to Seattle I owe you a beer ;-}
I had this same issue but when i turned off optional stop it worked for the first bit change but not the second?
Not sure if others are still having this issue, I found a fix for this, as I was getting frustrated with it not working. Unchecking the manual tool change box in the tool library settings changed the gcode to include the M6 code when a tool change was required. Works on both the onefinity masso and masso post processors
