ball screw side covers.
Check Etsy, there are a few options. There is plexiglass adapters that hold a sheet of plexi and there is also a brush option that I have seen ont there also.
Thank you Grant, greatly appreciated.
After seeing the side covered plexiglass idea I believe I will try making some simple mounts and give it a go. I have a good dust collection system but if I use the 1.5" surfacing bit and the large hole suckit shield I get shavings everywhere and took note on how much was being drawn in to the ball screws so figured I would try to eliminate the majority if possible.
