Hey everyone,
New to the Onefinity CNC. Trying to set the XYZ for my bit using the probe Onefinity sells, but when I run the probe XYZ command the spindle bit moves away from the touch plate and not towards it on all three axis. Please help!
Your video is private so we can’t see what it’s doing.
Should be good now for you to see
The video you posted does not show ‘Step 1’. Did you actually touch the bit with the touch probe block?
Have you upgraded to a spindle recently? I had the same thing happen when I did - the solution was to reverse the probe wires and leave the ground off the collet, since the spindle is grounded and the Makita is not. There are some threads about this on the forum.
