Bits coming loose
I have a Makita router for 1/4 " bits Some bits like my 1/2" round stays tight but it seems my 1/4" end bits come loose after a few minutes.
I have tried several different collets and several different end mills to no avail.
I have ruined several pieces of work because of this. I just finished 10 pieces doing an area clear my 1/2 round over bit with no problems. I thought maybe the bottom brg. might be bad on the previous router so I got another new router. Borrowed a bit from a neighbor who has never had any problems and his bit worked for one piece then it moved while milling the second piece and the mill time was only 5 min. not a long time. The bits are tight in the collet. Pulling my hair out on this one
Any thoughts anybody
Sometimes it is saw dust in the collet causing problems. Take the nut right off and clean it all out every time you change bits. There’s also a 3rd party that sell better machined collets. I think you can find information about these on this site.
I have checked for saw dust but think a better collet is in order if I can find one
Thanks for the info
There are other sizes available here:
These should fix the issue! https://www.onefinitycnc.com/product-page/premium-presision-collet-double-pack-for-makita-router
Thanks I think that will help a lot
