@349iq2345 thank you for a well written article.
Thanks @349iq2345. When I started down the road of automating the dust collection from the VFD, I suppose I didn’t realize what I was getting in to
as a non-electronics guy. Not exactly plug and play. I’m sure matching up relays and wiring in a diode is very simple for those who know, but a bit intimidating when you don’t, especially when attached to a fairly expensive VFD. But I’ve learned a good amount thanks to your generous and clear explanations. Take care
Hey Martin,
these two questions I forgot to answer:
Now the link works in my country too (strip everything except /dp/ASIN from the URL):
https://www.amazon.com/dp/B08GP8L31L/
no, a solid-state relay needs no flyback diode, because it has no coil to control it but a semiconductor (usually a thyristor). But this changes nothing on that on an open-collector output, you need a voltage to trigger the control input.
This one? External IoT relay (FAQ)
The little green input on the side is like the control coil.
Thanks for coming back to this, @349iq2345 . This has given me 3 good options that I can see:
- electromagnetic relay with 24v power supply and flyback diode. Thanks for the suggestion on the diode. If I can do this, it sounds like a nice option.
- possibly SSR with 24v power supply
- according to this U.S. manufacturer of relay modules, this 20A dry contact module supplies 24v to the control circuit off of the 120v power.
Yes, that’s the one. Sorry, I meant the requirements for it to properly interact with the open collector output. But probably won’t be necessary with the options above.
Thanks again
Hey Martin,
in this case, to attach it to open collector input, you just have to find out (by measuring, multimeter set to DC voltage) (or to ask the manufacturer) which wire is the DC positive. I would assume it is the red/white.
A power supply is necessary as the open collector output does not provide any voltage.
