I built my table a little too small and i want to make an enclosure but this will only work if i can flip the rail
I think this contains the information you are looking for …
thank you I only need to reverse the x rail if possible
I believe in the link shared Onefinity states you can just turn the x axis 180 degrees and switch the stepper direction. I am not using the 1F controller or steppers, but I think after rotating the x axis you can mount the z assembly on the opposite side. Unless I am misunderstanding your question.
