I was wondering whether the Carbide Create touch probe can be used with the one infinity machine. If so what are the steps needed to use it.
Hi Tony - welcome to the forums! You should be able to use it, you just need to adjust the wiring and set the right height/length/width settings in the settings menu. In the end, it’s just a circuit between the bit and the touch plate. I looked for a wiring diagram for the Carbide Create touch probe but didn’t find anything - you should be able to pin it out easily though.
