Carveco help with metric in tool paths
Switching from Easel & learning Carveco, Dimensions set to MM, but the toolpaths come up in Imperial, anyone help with how to switch, as I know what MM/min I want for most of my work & really do not want to have to go backwards. TIA
Look at the machine file to see what post processor is in use. I had the same issue but it was switching between Imperial and mm on its own, or so I thought. When I checked I had both the imperial and metric PP installed on the machine. Problem seems to be resolved after removing the metric PP. More projects completed will tell the tale.
Carveco support told me how to deal with it, you have to go in to each bit and switch it to metric, a bit of a chore but since I use very few bit changes it should not be too tedius to update.
