Does anyone know how to change the time on the controller? Mine is set to PST.
Thanks
Thanks
Hey Jen,
I asked the same question a few weeks ago. There is some code you can run on the Pi to force time zones et.c which in the end I did not feel was worth the hack so I did not do it. BUT if you search back you will see the posts to change it if you are adventitious. I’m hoping the OneFinity team adds this in an upcoming Firmware update as it makes seeing your end time very off.
-Alex
Bummer, Let’s hope that the OneFinity Team realizes that not all of their customers are in the west coast. I’m not interested in a hack either. A Firmware to address this matter would be appreciated. Thanks Alex for your post!
JENN
I’m in the west coast and when I load a file I just finished. It shows it was created “yesterday”. Proper time would help verify that I am uploading the right file. Gotta see what mine is set at.
following this post.
Honestly, I’ve never noticed the time was wrong. Is your OF on the network? Perhaps mine is using NTP so the time is right? Just curious - what’s the issue with the wrong time, other than the file time stamps?
Yes my OneFinity is on the network, and it’s stuck on pst time zone. I’m eastern, so it’s three hours off.
I don’t know how to do it through the GUI, but you can change it via logging in to the raspberry pi (your onefinity router). It Involves a few steps.
Looks complicated, but it took me under a minute…hope this helps
Note, if you are connected to the internet, the time should be correct, just your time zone is not
Cheers
Al
Great Tip Alan! Thanks, I’ll see if I have what it takes to do this.
