CNC freezing when starting
I am using Carveco Maker to machine a 4 sided 3d chess piece and did the left and right sides perfectly with a roughing pass and a finishing path OK. When I went to do the front side I didn’t need the roughing pass and went to just use the finishing path - both separate gcode files - the router started to move from the centre point to the job site and plunged ready for cutting but wouldn’t move after that - did recompile the gcode twice and closed the cnc and restarted it with the same result.
Anyone have any suggestions as what could be wrong?
thanks Kerry
Hi Kerry - is it the same exact file? If the controller does not give you an error or warning, it might be mechanical. Have you checked all your connections?
