CNC is not following toolpath properly (FIXED: Loose motor coupler)
Hello
My machine(gen1 foreman) ran fine and everything worked well. I shut it down, for the night, came back in the morning to start on my new project. I’ve started it, and then noticed that the cutout letters looked different shapes than what I created in my Vcarve pro 12.5. I never had this problem before, so I don’t even know where to look for a problem/s.
Included are three pics of toolpath data, preview of the toolpath, and actual carving of this project. Let me know if anyone ran into this problem and was able to troubleshoot it?
Tnx
Andre
Check your Z slider bolts.
Looks like some deflection happening.
I had a bolt shear off but visually you couldn’t tell. Only when I was checking for torque with an Allen key was it detected.
Motor couplers on x and y being loose is the first step we’d suggest. It looks like they are slipping.
@Ken5 @OnefinityCNC
Thank you, will check it out :+1:
So checked all that was suggested, and found that couplers on B1 rail was loose.
Tightened it, and back to business!:+1:
Thank you, Andre
