Crave is ending up squatty/ wrong size
Here’s what’s going on. Simple cutout of 1/4" plywood box. Pieces look ok in Vcrave Pro, I move the files to bb controller via wifi and view the file and everything looks good. I start the crave and everything goes great but the finally produce end up squatty. sides of boxes do fit together but The tops and bottoms are not square as they should be and when I measure sides they are not the correct size. I don’t get it. I have even tried other files with the same results. I must have something not set right. I recently went through a reinstall of raspberry Pi. 1.4.1 perhaps there is an issue with that?
please help - on my 2 sheet of plywood
Reset the configuration to your specific machine type and size.
Thank you so much. Got it
