Delayed shutdown of the 24v relay (aftermarket spindle)
Hey Fred,
I used the image that I used previously and modified it:
(I rotated the TRM01 so that its relay output points to the relay side. If we would be totally correct, the VFD would be on the left and the relays on the right, according to the rule “inputs left, outputs right” :slight_smile: but it was simpler for me to modify the previous image. I could also make a real circuit diagram, but I have not yet created a symbol for the TRM01 at the moment)
I hope that the X1 input works this way. :thinking:
PS: Ah I see your relay wiring is correct, you just flipped the colors! Better follow the conventions: Red should always be used for positive voltage, black for ground/negative.
