if you’re in manual mode, you must jog (move) your bit i.e. your milling motor closer to the touch probe before starting the zeroing process. You move it with the arrow buttons on display or with the gamepad if you own one.
If you’re in program mode, you can modify the settings in the “tool-change” field in the General Configuration Tab, → as described here ←. Often people have a default g-code in this field which may not be usable.
