Drives to left stop when job started
My Elite has a problem. Haven’t used it in 2 weeks, worked fine before. Now it drives the tool head to the left stop and no farther. Have tried 3 different files, same result. Ideas are appreciated.
Homing is working correctly?
Any faults/errors showing?
On the first time I turn it on(every time) during homing, if the z axis is at the top, homing z axis fails every time. I have to turn the threaded rod down a few turns then it works fine. For what ever reason my machine does not understand the Z axis top limit switch. Need to lower it somehow.
That’s the only fault. I got used to it and in the past went ahead and got the job done.
Today I turned it on, got the z axis fault, turn the z-axis down a little, cleared the alarm, and homed no problem. Loaded the file, positioned the bit over the corner start point, xero’d the axis’s, and hit the start button. It sat still for 20 seconds then drove the router to the left stop.
6 times, also moved it across the table so it had a different zero position , still drove to the left stop, y axis did not change.
