Strange Homing error
I have just upgraded my Pro Journeyman to Elite. Everything seems alright. I started it several times to test and check. However, just one time, I had a weird problem. The machine started to home and after homing the Z-axis it jerked the X-axis like 4 inched to the left (from about the mid point on the axis) and the motor showed the red light and the controller said that there was a homing error.
I tried homing again and the same thing happened. It pulled the X-axis to the left very quickly by about 4 inches and showed the error. At this point I turned the machine off, started it again and everything worked fine this time. I have not seen this issue any more, after about 10 starts.
Do you guys have any idea what that could be? Has anyone seen anything like this before?
Can you post a video of this?
No, this has only happened once and I cannot reproduce it so far. If I could I would have asked the support, yes. Thank you.
