X and homing issues
Just assembled my onefinity journeyman elite twice!
Put it all together following the videos and was playing around for a while before i flattened my waste board. Thought everything was going well and half way through the machine messed up and started moving back the opposite way of the tool path and then went into alarm. So started trying to troubleshoot. Oiled everything again… took the whole thing apart to check and make sure nothing was loose. Read and searched on the forums for a while and now it will home… but when i move the x to the left its ok move to the right and oly moves a couple inches and stops, move the Y+ and the X moves also.
I hope some smarter than I people can help
What message does the alarm give? Are there error lights on any of the motors?
Its shows a Y motor alarm. I reset and do it again and it shows an X motor alarm. Someone in the FB group said that it might be in the machine settings… in the F3 page in the machine box it is showing an A position but not B position… i was just looking at the masso documents and cant see how to change this. Im looking for any suggestions
Please reset the configuration settings:
I have done this a few times already. I will format the USB and load it on there again and try it.
so I just did the settings again. homed it and its still not correct. when homing i noticed as the X was moving left the Y was going backwards until the X was homed and then Y started moving forward. I checked the setting for the inverting of the motors and they seem ok. i think.
