Hi Folks, I have the Gen 1 Elite with Masso and am trying to configure my Easy ATC. I’ve checked my wiring and config over and over but cannot get my Masso with Easy ATC to detect a tool (Finding Z). The LED is green all the time, when I break the beam it goes a little brighter green but when I run the gcode to find the z position it reports back that the beam is clear. There isn’t much documentation on troubleshooting. Hoping someone can help. I’m happy to supply my config. The only video they supply for setting this up shows the LED as off until the beam is broken, then it is orange. Mine is nothing like that but my Easy ATC is the latest version which is a little different. I have read the docs over and over as well and cannot find an issue with my setup.
From what I have learned from reading posts is that the LED being on all the time may be the issue - it should not be. I would reach out to Don at Rapid Change as he can tell you right away if there is an issue with the circuit/board.
If you have discord they have a great team that usually respond in a few minutes there. I only have experience with their solo which doesnt have the IR sensor so I cant be of much help. If no one else can help here you can always reach out to Rocco at support@RapidchanceATC.com who seems to run their support.
I don’t have discord. I have sent a support to rapid change so hopefully I get a response soon.
It’s been a while since I set mine up, but I think I remember that the control line for that sensor had a separate line that had to be connected to +24v inside the controller. I know enough electronics to know that that was probably a pull-up resistor and that the sensor was just an open collector output. If you forgot to connect that line, connected it incorrectly or possibly had it not reliably screwed into the screw terminal I would expect to see that type of issue. The output would float near ground when it otherwise should be +24v and then would go to ground when triggered. This could explain the light being on all the time but going brighter sometimes. It’d be the first thing I would check if I had this symptom
