Greetings Onefinity/ATC Community,
We have been working with Onefinity, Redline and RapidChange to integrate native support for the Easy ATC into our controllers and software.
In order to consolidate the discussion for the new Easy ATC support and beta testing, we will be posting updates and answering questions on this thread.
Updated Post Processors
We have posted updated post processors for Carveco, Vectric, and Fusion 360 on our website here:
Beta Software Downloads & Installation
Redline HMI
https://firmware.realtimecnc.com/public_beta/RTS1.1.5.7.tar.gz
If you are downloading this file on a Mac using Safari before you install it on your Redline HMI, please read this important note.
- Download the update file on your computer and copy it to a USB flash drive. The drive should be formatted as FAT32 or exFAT. Do not change the file name. It should appear as RTS1.1.5.7.tar.gz
- Plug the USB drive into a USB port on the HMI.
- Select UPDATE from the drop down menu in the top toolbar.
- Choose “Update from File” and select the RTS1.1.5.7.tar.gz file from your USB drive. Click the IMPORT button to start the update.
- After the update has completed, the software will restart automatically and update the controller firmware.
Windows
https://firmware.realtimecnc.com/public_beta/RTSX-Setup-V1.5.7.exe
Download and install the beta software using the setup executable above.
Mac
https://firmware.realtimecnc.com/public_beta/RTSX-Installer-1.5.7.dmg
Install the software by downloading and opening the DMG file above. Drag the RTS-X application into your Applications folder to install it.
FAQ
How do I set up the ATC?
The software now has a dedicated SETTINGS page for the Easy ATC. It also includes a setup wizard which will walk you through setting up your ATC.
Advance information on the new settings are available here:
Which Easy ATC Magazines are supported?
The first software release will support four slot Easy ATC magazines. These are classified as V1, V2, and V2.1. These models were sold by Onefinity through their website.
I have a different RapidChange ATC, will it work?
Maybe! The first beta release will not support dust covers, but it does expose all the parameters necessary for setting the tool setter position and parameters. Only the magazines mentioned above are officially supported.
When will the beta software be available for testing?
The beta software is available for testing now
I am not comfortable using the beta software, when will the official release be available?
We expect the public release will be available by the end of April. We will be responding to all beta tester feedback in the mean time.
What do I need to enable the ATC?
You will need the following:
- The 1.5 beta software release
- A compatible Easy ATC magazine and its accessories
- Collets and collet nuts
- A tool setter
- A compatible VFD spindle (Redline or equivalent)
Will you be adding support for other RapidChange ATC systems such as the Solo?
Yes. Support will continue to expand in future software releases.
How many tool changers are supported?
The first version will support up to 4 tool changer magazines (16 tools total).
Are there restrictions on mounting the magazine?
No. As long as the tool head can reach the magazine slot, the software will work. The magazines can be mounted in any position and in any orientation. The software tracks the location of each pocket independently.
We are excited for everyone to start using their Easy ATC systems. Please post any feedback or questions in this thread.
