If you go to Mitchell’s Woodworks on you tube he just did a fantastic video about the tool setter.
I will try the MASSO post. I had issues with Fusion. Thank you!
Here’s the best guide on the tool setter: https://www.youtube.com/watch?v=w7auvta0g44
Great video, helps. I am curious where his secondary connection to his touch plate is connected. I sometimes forget to attach it to the spindle, with poor result.
Same here; I typically forget when I’m using a nice bit. I’m guessing he has continuity between the spindle and the QWC frame. so he can connect to the QWC.
My bit is a 1/2” four flute I am using to mill aluminum. After homing the machine, I pressed rewind and start cycle and it went straight down and started drilling into the tool setter, but if I tell it to go to work origin after it homes and measures the tool, then press rewind and start cycle, it goes right to work perfectly. Why would this happen?
