The Tool Setter settings in the F1 page should be green/low. If yours is set to red/high, follow the steps below to adjust.
Go to the f1 page.
Hit enter.
Scroll down in the center column.
Find Input 11 line labeled “tool setter”.
Single tap that line so that it is highlighted. Do not double tap the line.
Push the space bar to change it from red/high to green/low. Ensure it is green/low for correct operation.
Reboot the machine and try again.
