TOOL SETTER F1 INPUT 11:
If you have a tool setter, ensure input 11 tool setter is set to green/low.
To change:
- go to f1 page
- push enter in the password field (password is blank)
- SINGLE tap the input 11 and push the space bar on the keyboard at the bottom.
- this will change from red/high to green/low (and visa versa every time you tap the space bar)
- the correct setting is green/low
- Reboot
- Enjoy!
TOOL SETTER F1 AUTO TOOL ZERO SETTINGS
- Check Enable auto tool zero (purple arrow)
- Do NOT check only auto tool zero when manually requested (green arrow)
- Tool setter X position (yellow arrow) Check Enable (value is user specific to wherever you placed the tool setter)
- Tool setter Y position (yellow arrow) Check Enable (value is user specific to wherever you placed the tool setter)
- Z safe distance to tool setter (purple arrow). Ensure its set to -1.00 (inch)
- Tool zero feedrate (purple arrow). Ensure it’s set to 30 (ipm)
- Done!
(Purple arrows are values that must be exact and not user changeable).
(Green arrow should be unchecked.)
(Yellow arrows are user specific variables that the user will input.)
(Red arrow is set to inches in this case. User can change to MM as well.)
