Elite drag chain hitting screw
After the elite upgrade (which went really well and I am glad I did) I encountered a small problem.
If I move the z-gantry to the right at one point the dragchain will hit the screw at the back of the x-rail.
I am not sure what the purpose of the screw is. Am I the only one having that problem?
Did anyone find a solution?
Mine contacts here also. I may replace it with a grub screw before it snags the drag chain. I don’t know exact purpose of it.
Excellent idea! Thanks Steve!
I found out that those are tramming bolts, I remember tramming the X axis a long time ago.
ARE THOSE M5?
I had the same issue and ended up replacing with an M5 grub screw. Probably a button head screw would also work.
