Hey Mrd,
they said they still have a lot of documentation to make.
Here ← is the footprint of the Elite Foreman, the width dimension should be identical.
What I would ask myself (If I were interested in one of those machines) is if when you choose the 80 mm spindle option, whether you get a wider drag chain…
The ones you see on the pics are not wide enough for coolant hoses of water-cooled spindles. A full-blown drag chain with spindle cable and two coolant hoses is usually 50 mm wide.
