I have another issue I tried cutting the onefinity that was already uploaded to my machine when I got it someone suggested that , because I keep getting error codes when I try to carve anything . This is the error code I got with it . Is there like a reset of some type I can use to try and fix all the code errors I’m getting .
There will not be anything wrong with the machine.
Have you homed the machine?
Have you checked your heights in the CAM vs where you are placing zero. E.g. zero off wasteboard or of stock top…
I was getting these same error messages. Turned out I had my safe Z set too high. Once I lowered that to about a half inch I never got the error again.
